Oil / fuel leaking into area behind transom
I am currently running a 1975 Evinrude 80HP and whenever I shut down the engine and trailer the boat home, there is always some oil/fuel that leaks out into the area behind the transom.
I always clean it out because i don't want any of it to wash into the water next time I go out.
This also happened with my 1976 Johnson 135.
What might cause this to occur?
Thank you,
oldrudedude
Re: Oil / fuel leaking into area behind transom
I think you are saying that when you tilt your motor up and trailer it, gas/oil mixture leaks from the motor into your splash well. My 1971 does that also. I am told it is normal. The mixture leaks from the carb float bowls because the float can not hold the needle closed when the motor is tilted up. Not very enviromentally friendly, but in 1975 the eco standards were much less strict.
oldrudedude,
Is there anything I can do to lessen the amount of oil/fuel that leaks into the splash well?
Something like putting the boat on the trailer and then disconnecting the fuel line and letting the motor run itself out of gas before pulling the boat out of the lake?
oldrudedude
I always disconnect my fuel line at the engine before I take the boat out of the water or if it is sitting at the dock and not being used. When I first noticed this problem someone suggested that I could run the engine with the fuel line disconnected until the idle begins to stumble. This uses some of the fuel in the bowls and reduces the spillage. Someone else commented that running the engine out of fuel is hazardous to the engine because the fuel/oil mix is the all that lubricates the engine. The point being that if one or more cylinders runs out of the fuel/oil mix while the engine is still running those cylinders may suffer damage. I think this is a very legitament point especially if you concider that it is probably the same cylinder that would run out first every time. It would result in chronic wear to that one cylinder.
It sounds like you are trailering with the fuel line still attached to the motor. If that is the case, when you tilt the motor up, the pressure in the fuel line is probably forcing the fuel past the float needles and you are getting spillage into the splash well. Removing the fuel line from the engine before trailering will probably eliminate most of the spillage.
For myself, I remove the fuel line as soon as I get to the ramp. I will let it run for a few second (maybe 15 seconds) but not long enough to have the idle stumble.
Keeping the detractors in mind, develope a proceedure you are comfortable with.;)
oldrudedude,
Thank you sir for the good advice.
I will do as you suggested and see how much leakage occurs.
Thanks again
