Oil/Gas Mix ?
Delta22710
Hi again, Rookie question> I have a 1984 Bayliner with an 85HP Force Outboard. Does this motor need an oil/gas mix or can it just be run with straight gas. I added the 50:1 oil/gas ratio yet when I start up the motor it smokes a heck of a lot and it idles a little rough (sputtering). I changed the gas tanks to using straight gas and it sounds better, little to no smoke, and no sputtering. I am now wondering if I even needed an oil/mix in my fuel.
Also What octane gas should I be using?
Any suggestions on either question ?
Georgesalmon
Re: Oil/Gas Mix ?
you NEED to mix oil in the gas. RIGHT NOW!! Any octane will work.
roscoe
Re: Oil/Gas Mix ?
If you run with no oil, you will have no motor.
catfishcarl99
Re: Oil/Gas Mix ?
hope you didnt run it long. no oil in it for more than a minute or two youll be hammering out pistons. like running to work with no oil in your car. 2 stroke engines smoke. just how it is. do NOT run it again with no oil or you will be paddeling your vessel.
Jiggz
Re: Oil/Gas Mix ?
Wow, you're a real tough guy! I hope you have enough money for a new motor or maybe for a used one!
Delta22710
Re: Oil/Gas Mix ?
Jiggz, Like I said, ROOKIE Question, which is why I am using forums. Ill add oil to the gas, I think I just put too much in last time. As far as being a tough guy, come up to Plaistow NH and lets see who the tough guy is !!
Davem3
Re: Oil/Gas Mix ?
hey, i live near you.............. i think 50:1 is right , also try decarbing the engine as well........
welcome aboard , delta ..............
roscoe
Re: Oil/Gas Mix ?
Decarbing the engine is a good idea.
Can also switch to synthetic TCW3 oil for less smoke.
Its possible the previous owner had too much oil in the fuel tank.
