Re: oil/gas ration for 25 hp, 69 Evinrude
Hey, Bo1.<br /><br />If spraying some WD-40 in the spark plug holes is "running some oil through it" I agree. Turn it through slowly by hand to make sure everything is free before you reinstall the spark plugs.<br /><br />It probably should have a new water pump impeller before you try to run it.<br /><br />Fresh, 87 octane unleaded, alcohol free gas. TC-W3 rated outboard oil. 50:1 ratio (1 pint oil/6gal gas or 4oz. per gallon).<br /><br />Give her a try and let us know what you get.
