Re: oil hose replacement
Sorry, I do not understand the question. I would think just the oil line can be replaced easily. You will need to bleed the oil line and the OMS pump. The best way to do that is to replace the oil line and primer bulb, fill the oil tank. Pump the oil primer until all the air is out and then connect it to the OMS pump. Now one more pump to prime the OMS pump. Now run 6 gal of 50::1 premixed fuel and make sure the engine draws oil from the oil tank.
