Oil in ejection problem
Michael aguirre
I have a 60hp that has been bored 3 over runs great. But I have to keep pumping the oil bubble to keep oil alarm from going off what do I check to fix or how can I by pass and per mix
boobie
Re: Oil in ejection problem
To bypass the oil system, check the Top Secret Files at the begining of this forum.
Chris1956
Sounds like an air leak between the primer and the oil injection pump. Of course it could be a bad oil injection pump. Replace the oil line and see if it gets better. Premixing fuel is a good idea until you figure out the issue.
