Oil in Exhaust
rlebla4
Does the presence of oil in the exhaust pose a problem? I am running a 2003 60 hp 4stroke Merc. after running for an hour or so, I have noticed oil running from the exhaust port down the motor cover. I'm not sure if it is lower unit lube or engine oil.
The Marine Doctor
Re: Oil in Exhaust
There was an update listed for the 60hp Fourstrokes about the adapter plate bolts breaking off or coming loose.<br /><br />Also..check the T-stat to see if the engine is running rich.<br /><br />TMD
