Hi guys, I've got a 1991 4 hp Johnson seahorse, I haven't used it much in the 6 yrs I've had it but will start to next season, I've taken it out 2 times this year after draining the carb and cleaning the plugs, it ran good the first time going basically full throttle for a half hr no issues. Then the next time out we just putted around a bit over idle for half hr, again no issues while running. My 2 issues with the motor are thus.
1 - after the slow outing there was quite a bit of oil collected at the water intake (just above the prop hollow area)
2 - before starting the motor the 2nd time out the rope wasn't engaging the fly wheel, opened the cover didn't see anything obvious then put the cover back on and smacked the top of it and voila started right up....not sure what would cause this.....
I'm not much of a mechanic so any advise would be awesome. Oh the gas mixture is 50:1
Thanks
Thanks
