Oil in the bilge
KetchiMan
2004 Merc 5.0L EFI in a Trophy 2359 (Bravo 3 outdrive)
I recently turned on my bilge pump and had a nasty sheen of oil appear next to my boat. After investigating the bilge, there is visible oil. My bilge is almost always dry, so I have no idea how long this problem had been going on. After about 10-15 hours driving, the engine was about a half quart low.
I'm certain there are many possible causes here, but I'm no expert, so I'm looking for some help. Where do I start? What are the most likely possibilities? What do I need to know about this before I start digging in?
Thanks.
tpenfield
Re: Oil in the bilge
The possibilities are . . .
Motor oil from a pin hole in the oil pan, or maybe loose oil filter.
If you have the remote oil filter, then check the hoses that lead to/from it and the oil cooler.
Could be Gear lube from the outdrive reservoir
There are a few more, but those would be good to start with
achris
More fish than mountain goat
Start by gently touching the sump with your hand.... When you find oil, start backtracking it. Can't offer much more help than that....
Chris.......
