Re: oil injection and mixed fuel
On a brand new engine you are supposed to run extra oil for the break-in period, so that would be fine running premix plus the stock oil injection. After the break-in you can just quit using premix and just use the stock oil injection.
On my Yamaha's I have disconnected the stock oil injection systems and just run 50 to 1 premix, I now don't have to worry about an oil pump failure (although I've never heard of one breaking), or an oil line coming off the carb, if that happened while you were running you wouldn't know it until it was too late. I also now don't have to clean up spilled 2 stroke oil off my ski from overfilling the tank cuz it's hard to see the tank and fill it at the same time.
Running premix is not any more of a hassle than dealing with an injection system, the oil is in the fuel so you don't have to worry about mechanical failure or a loose oil line. I use a Ratio-Rite cup and add about 12-1/2 ounces of oil into a 5 gallon jug, fill it with fuel so it mixes, then pour it into ski.
Happy riding!
