Oil Injection Buzzer
jim 1983
Goes off for 10 seconds after coming to a idle after running fast. Can you by-pass the float sensor when it is going off to tell if it is the problem?<br /><br />Someone told me that you can just run a wire from the ground to the bullet conector on the blue wire. Is this correct?<br /><br />Thanks
suzuki115
Re: Oil Injection Buzzer
I beleive you can simply unplug the sensor at the bullet connector. I may be wrong, but give it a try.
LubeDude
Make sure your under the cover tank is purged of air, It needs to be completely full.
