oil injection problem on 2008 60 horse motor
jsharp
I have a 2008 mercury 60 horse carb im having allot of problems with the oil injection dumping too much oil in the motor and fouling the plugs is there any way to adjust the oil its putting in the motor or is there any way to remove the oil injection system and go back old school thanks for your help guys
CharlieB
Re: oil injection problem on 2008 60 horse motor
Have you had the carbs off recently before this problem?
I have seen the oil control valve linkage reattached with the valve turned 180 degrees off the correct position, leaving the valve near wide open at an idle and reducing oil flow as the throttle is advanced.
Check the first 'sticky' post at the top of this forum, follow the links inside to the service manual for your model. Look up the oil pump/valve linkage and adjustment, verify that it is installed and set correctly.
jsharp
thanks i saw the sticky but it sid it was for up to 89 models this is a 08 and i cant get it to work.......... no the carbs have not been off this is a brand new motor it was bought new in 2009 i have maybe 30 hours on it i just think that it is getting to much oil is there an adjusment or something
CRFan1
That motor should be under warranty...bring it back to the dealer! :)
jsharp
it an 2008 is it still under warranty? if so great ill tell him to take it to the dealer
CRFan1
Should be 3 years from purchase date.....
