Oil injection pump leaking oil
Dave1027
Engine is a '88 Merc 100hp 4 cylinder 2+2 but I think this oil pump is common to any that has oil injection.
Seems a seal may have went bad in the pump and oil was leaking into the motor and draining through the lower unit..
Is the oil pump servicable? My Merc manual does not cover rebuilding the oil pump. How do I replace the seals?
I removed the pump from the side of the motor and the outer black rubber seal seemed to have come out of it's seated location and oil was seeping out. I push it back into a fully seated position and reattached the oil line to it. The oil seepage seems to have stopped now but is the black rubber seal going to pop out again?
