I have a 2004 50 hp ELPTO. It has the oil injection system on it. I have had people tell me that the nylon gear in the system is only good for about 10 years and if it goes it will cause the motor to blow. My questions are:
1. Is this correct?
2. Does the 50 hp have an alarm for this problem?
I do not know the answer to these two questions and hopefully someone here can give me the answers. Also, would you recommend that I continue to use the oil injection system or would you recommend that I start to mix the oil in the gas tank?
Thanks,
Randy
1. Is this correct?
Thanks,
Randy
