Oil Injection Systems
mcgill
Hello
Some The I Do Not Understand About This System .The Container On The Boast .How Come The Oil Just Dose Not Run Out. What Keep The Oil Form Just Runing Out is there some type of check valve in the oil pump?
DukesFin
Re: Oil Injection Systems
There are two containers on the boast...
One is the reserve tank (the one you keep filling) and I don't think there's a reason you'd be wondering about it "running out"...
The other tank or "Main" tank mounted on your power head...
The oil is fed via gravity down to the metering pump that is driven by a shaft in the power head. If the shaft isn't moving, the oil isn't being pumped.
Make sense?
rodbolt
without a model number we simply CANNOT help as there have been various changes to the control circuits on the V configuration motors since they were imported in 1984.
if its an inline motor there have been at least 3 pump changes since 84.
in other words post a model number and try to clran up the description.
They are pumps, the amount based on the rpm of the motor, the oil is fed to the motor gradually, not just open or closed.
rodbolt
there are check valves in the pump or line depending on WHAT yamaha and WHAT year we are disscussing.
other than that we cannot say more.
WE simply dont know what motor we are disscusssing as I am behind a monitor I cannot see your engine.
mcgill
Hello
Thank You So Much. I Just Got This Motor 1987 Yamaha 150hp Pro-v Motor. Ther Former Owner Was Saying Somthing About A Check Valve Needed To Be Repl, That Is The Reason Why When Set It Up For Two Weeks Or More.the Oil Runs Out,so Do I Need A New Pump, Or Check Valves?
Thank You
rodbolt
the original pump was a kien unit the replacement pump is a mikuni. the kien check valves are built into the pump the mikuni uses inline check valves.
the kien pumps have 6 outlet nipples pointing up the mikuni has 6 outlet nipples, 3 horizontal on both sides of the pump.
no fixing the kien you will need the mikuni pump kit as the kien was taken out of production in 1990.
