Re: oil injection
Welcome to iboats.
Do you have a VRO2 or the OMS system? What are your reasons for wanting to re connect?
1 - Remove the plug for the oil line at the engine, re installing oil line. Trace the wires from the back of the VRO to its rubber plug and connect it for the electrical.
2 - Connect the two wires from the oil tank to the engine
Test the heat warning system by having the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
This should help with testing
"http://www.boatpartstore.com/vro.asp"
Some more useful reading.
"http://continuouswave.com/whaler/reference/VRO.html"
