oil injection
Model # of the motor ?------I would take the VRO apart for inspection.----Re-assemble.---Clean out oil tank.----Replace filter in oil tank.------Then prime the system.-----Run motor with 50:1 mix and run the VRO output test.-----Run with 50:1 until you verify VRO is putting in correct amount of oil.
