I got a beeep beep ....warning on the alarme at over 4000rpm's and traced down the problem to the oil pump gear. My oil pump gear that drives the oil pump shaft appears to be made of plastic and has sheared off most of its threads inside the shaft housing. I vacumed all of the shavings, and the pump works at low engine RPM's.
How much of a job is it it to replace this gear in the engine block, and what is the downside of removong the pump shaft and just running motor on 50/1 premix??
Engine has about 300 hrs of runtime and warm compression is 115psi on 5 cylinders, and 85psi on the #6 bottom cylinder.
Any ideas as to why this gear failed??
Is this a common problem??
