oil injector system, bypass
royal
I have a two part question. First- for piece of mind I think it is okay to remove the one gallon oil tank and plug the lines, then mix my oil with the fuel at the tank.(Is this okay?) Then where would the best place to be to disconnect the beep beep alarm which is coming from the Gear shift control box? I am sure the oil injector system is working and the reserve tank is full and there is no water in the filter. Just tired of listening to the alarm.........Thank you for your help. </font></li><br />[*]<font size="2" face="Verdana, Arial">oil injector, bypass [/LIST]
clanton
Re: oil injector system, bypass
You would still need the alarm fo overheat. What kind of engine are you using?
