neverenoftackle
- Nov 1, 2004
- 7
I own an 86 150 hp XR2 Mercury--2nd owner purchased it on a Ranger in 87. Been a good in. After fishing with a friend of mine (XR6) he informed me that he knows a number of guys pre-mixing their own oil. They have disconnected their oil injectors because of no warning past the pump to the engine, and the trouble this has caused from oil starved engines, if something happens in this area while runing. Is this prevalent out there in your alls world? SecondI have a Merc. Pressure gage reading 15 psi at 4000rpm, and have changed the pump regularly down threw the years, BUT for several years now the temp gage has been riding just beyond the ¾ mark at 4000 instead just below ½ as it use to. Drops back to normal at idle. Stats check out, was told that I could have thrown a piece of pump impeller at one time and it lodged in one of the blocks water passages. He says to take out the thermo stats and run with out them. What problems does this incur? Can I do it?
