oil - intake
marvxyz
It looks as if when I run my 6hp 1990 evinrude oil seems to be coming out the water intake hole. What could be causing this?
D
DJ
Guest
Re: oil - intake
More than likely it is unburned exhaust.<br /><br />However, have you checked the lower unit fluid lately?
marvxyz
Re: oil - intake
Seems like I may have too much oil in the lower unit. If I remove the top(fill) screw, oil flows from the top hole when the motor is upright.
jy118lfd
Re: oil - intake
Check for water in that oil. For it to overflow there must be something adding to the oil
