Dutchlarson
- May 28, 2015
- 33
Hi everyone,
I took my boat for a spin today. Its a 2003 Larson 210lxi with a 5.0 mercruiser.
Just out of curiosity i checked the oil, but it seemed the stick was clean. There seemd to be some clear oil on the last inch of the stick. It scared me a bit, but on the other hand, it just had an oil change at the dealer, and i check it with a hot engine just after. I turned it off.
Could it be that the oil is just very clean and also very liquid because the engine was still hot?
I turned it back on, and the oil pressure seemed also a bit high, around 55psi when idle.
What do you guys think? Then engine runs and sounds normal.
