oil leak bravo 3 sterndrive
stranden720
20240512_160247.thumb.jpg.8b169cabc8a7bbc7a007c251bb465a1f.jpg hi, there is a little bit of oil leaking in a small opening on the right side of the sterndrive just by the shift cable mechanism. Loosened the sterndrive and see that there is a small channel there. Does anyone know what channel it is?
alldodge
Welcome
In the upper left corner of your second pic is where the quick connect lube bottle connects lube bottle to drive
If it was leaking there before the drive was separated then most likely needs new O-rings. If it leaked after the drive was separated then that's ok
stranden720
Welcome
Thank you. I see. I had a guy her that replaced the bellows and I saw the leak after. But what is the opening at my arrow.?
