Oil leak from bolt on outdrive
jminz
Hi there, new to forum and relatively new to boating (as an owner)
Noticed this leak from a bolt on my outdrive today. Was hoping for some direction before taking it into the shop.
2005 Rinker Captiva 192. 4.3l Mercruiser. Alpha 1
Bt Doctur
there are no oil passage by the bolts, but the GEN II does have an O ring between the top and middle bolt
tpenfield
There is the oil passage (valve assembly) in between the two upper bolts shown in the picture. . . .
Are the bolts tight? Recent servicing of the outdrive?
jminz
The boat was purchased and service last summer. Is this something that needs to be addressed immediately?
tpenfield
Well you will be putting out an oil slick when you put the boat in the water . . . So yes.
I my experience, you do sometimes get a little bit of oil seepage from the valve if the outdrive is not 'driven home' quickly enough during installation after servicing, and subsequently, you can get a little bit of oil discharge from the area.
Other possibilities are the o-ring is failing or the bolts are not tight.
Grub54891
I'd pull the drive and check that o-ring. You don't need water getting into the drive,what comes out,let's water in.
jminz
Is there a torque spec for these bolts? I'm going to tighten, clean it and see if that stops leak.
Bt Doctur
you need to remove the drive to make sure the O ring is there. Once you lose the oil ,YOU LOSE THE DRIVE
tpenfield
50-ft lbs . . .
Unless the bolt is obviously loose, you should pull the outdrive back from the bell housing to get a good look at the condition of the o-ring.
jminz
Could the oil I'm seeing around that bolt be residue from winterizing? I tightened the bolt a half turn, and also cleaned around the bolt. No additional oil has leaked.
Bt Doctur
The problem is your sig says a Alpha and the oil fitting is on the Alpha GEN II drive. We need more pics to determine the type. do the hyd rams bolt on or slip on?
There is no winterizing process involving an oil leak in that location. The GEN II has a O ring seal in that area, the standard Alpha does not.
tpenfield
My advice is to do a bit of degreasing/cleaning in the area and see if the oil comes back (or not).. If not, then it may have just been the loose bolt . . . if not, then best to look at the o-ring.
jminz
I'll double check, but boat is a 2005 model, would that not dictate a Gen II?
jminz
I'm taking it in today to be safe, hoping it was just a loose bolt
Bt Doctur
If should be, that's why I posted that link, but sometimes things get changed
jminz
Took it in today. The oil on the bolt was residual oil from last time unit was serviced. Preciate all the input from everyone.
