I have a small amount of oil leaking down the shaft after running my 2003 225hp evinrude ficht for a while. Doesn't seem to amount to much but is annoying & messy. the twin motor does not do this. anyone have this problem or any suggestions?
Check your oil lines and oil pump for leaks and inspect throttle body shafts. If oil running down shafts it the oil mist condensed in intake. There was a kit for the shafts at one tme if I remember correctly....
