Oil leak mid section
jatr24
Hi
having an issue with straight 2 stroke oil leaking down the outside mid section of a 1996 johnson ocean runner 200 hp
Any ideas
Thanks
Chris1956
The gasoline in the carbs evaporates very quickly, so your leak could be from one of the 6 carbs.
Alternatively, but less likely, it could be a leak from the oil supply line to the OMS pump, if you are still using oil injection.
The only way to find it is to look.....When motors are tilted up, the carbs often leak. This can wait until you tilt it down again, to leak out.
