The gasket blew by the oil filter on the timing chain cover. Have to take off the front motor mount and harmonic balancer to get to it. The harmonic balancer pully is pressed on and the gasket is attached to the oil pan also. The pully is stuck how can I get it off? I'm using a puller tool for harmonic balancer, should I try a breaker bar? how do I get it back on? hammer and piece of wood? or is there a tool? Also what kind of gasket sealer to use permatex 2? has anyone done this without pulling the motor?
