Bigskywolf
- Mar 27, 2004
- 5
First I need to know engine yr Sn# DE124503 supposed to be a 96 force 50 horse.Just bought the boat off a dealer he claimed he didnt know the yr.2nd how many water outlets are their,I have 1 under the cover 1 on the port and starb. side of lower unit 1 just above the prop,1 on the front side half way down.and 1 I dont think should be their its on the port side just above the lower unit gasket a little square whole that I think should be sealed???I noticed milky water out of the prop after flushing then 8 hrs later after sitting black oil from the prop,also the water out lets after flushing seems to be oily or gas in it.I red tht forces need to be decarbed fine and will check lower unit oil in am.I will dump the gas in the tank and re fill but at what mixture.It starts on first turn Idles good throttles up good compression at 135,132.could all this be just needing new plugs and gaskets its been sitting at least 2 yrs thanks all from florida
