Re: oil leak
It is possible that your o/d has a leak in the upper seal at the ujoint.I just had mine replaced.My bellows was full of gear oil.If the smell of the oil is strong enough to smell without touching it and putting it up to your nose,then it is most likely gear oil.By the way,if it is gear oil that means you also have a leak in a bellows.Check your gear oil level. Charlie
