Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i have an oil leak in the lower drive unit of my penta volvo 1997 7.4liter. It has a strong odor...not fish! could this be gasket leak or serious problem
Doubled...Is it leaking in your bildge area?..If so then you have a seal problem...(A mechanic replaced all of mine and impellar for around $500...If it is leaking from your lower drive (on outside of boat) it may be drive fluid fill hole seal..whiach is easy an inexpensive to replace..I also put thread sealent on it for extra sealing....hope this helps....pete42
