Oil leaking from between stern drive and propeller
4Winns24
Hello Everyone,
Yesterday I ran the boat (2000 Four Winns Cruiser with VP V8 5.0 L engine) on muffs and today I noticed oil leaking from the bottom of propeller onto the stern dripping down. I have never seem this before. Can someone please shed some light into what is happening with this boat? Here is some pictures:
GA_Boater
Welcome aboard.
Drain your lower unit lube and see how much water is in it. A leaking lower unit allowing water in can force the lube out through bad seals that let the water in.
4Winns24
Thank you :)
Does it make any difference that the oil is very dark and not milky looking?
As a background, she has been sitting for a few months and in preparation for the season I changed riser/manifold and ran it on muffs for two days on a row for half an hour each. Then this happened 🤔
pull your prop, you most likely have fishing line wrapped around the shaft that has cut the shaft seal
so at a minimum, your replacing a few seals and changing fluids.
