Ok. Here's what happened. Last fall I decided to change the oil on my 5.7L volvo penta engine. The filter was on so tight, I had to have a pro come in and remove it. I bought the boat used and can't remember who changed the oil. Think it was the dealer but I have not proof. Anyway, after about 5 hours the filter finally came off. I knew that I would have to check for leaks in the spring once I started the engine. Well wouldn't you know, it leaks. In fact, it leaks so bad that I lost all the oil in about 30 sec - 1 min. Thank God the engine never got warm. After a two hour clean-up, I'm begining to wonder (pray) that maybe we put on the wrong filter. That may be wishful thinking. I'm looking for worse case senerio here. What else can be causing the leak and what's the fix?
