MontrealSeaMonster
- Jun 19, 2010
- 10
'94 60Hp 3 cyl
After some investigation to my oil leak. I think it's leaking past the zip ties on the oil pump inlet and outlet. I've cinched them at tight as I can because I used to be able to spin them around a bit, but I still see a bit of oil on the other side of the ties though the clear supply lines. Never actually seen it drip. Just a puddle in the cowling.
It seems to only happen at WOT because I idled in a trash can for 30 mins or so without a drop. Hard to poke my head in there running at top speed. Last outing it was too choppy to give much throttle. Didn't really seen anyting I'd call a leak.
So I'm wondering if a faulty 2 PSI check valve (where it "T's" into the fuel pump line) is causing too much pressure in these lines when the variable oil pump opens up on WOT.
Wondering if that's possible or I should start taking the pump apart...
