speckledredbass
- Jan 10, 2008
- 3
Where on the dip stick does it show the proper oil level in the engine. I know some engines are near the bottom, and how is the best way to check the oil in a 4 stroke do they vary from brand to brand. How often or when should you change it. I have a 2002 DF50 which I bought around March and it only had 22 hours on it. It was in the shop getting serviced when I bought it, they did regular maintenance, and replaced some sensors. So I figure the oil was changed then, it is clear on the dip stick. Any suggestions are appreciated.
