Re: Oil Lift Pump
Use a pressure gauge at the sender fitting and run the motor. It should be 4-20#, also check pressure regulator if not within specs.<br /><br />Remove each pulse line and use a vacuum pump to see if it holds. If it leaks, there may be a hole in the diaphragm.<br /><br />Your best bet is to order a service manual.
