oil line ?
tjbass
I have a 1998 90hp johnson that i had to rebuild. on two of the intake bypass covers there are two nipples for oil lines on the starbard side there is one oil line plug in which i have ran but on the port there is another one and not sure where it gets ran or if it even gets an oil line to it.
Chris1956
Re: oil line ?
I will assume you do not have a service manual, since the data is in there I believe. Didnt some of those lines run to the airbox?
ezeke
Re: oil line ?
The single small nipples on each bypass cover are for the hoses leading to your recirculation check valves.
R.Johnson
Re: oil line ?
If you have done a rebuild, check those recirc. valves also, that is also in the service manual.
