Jerry_NJ
- Aug 23, 2010
- 250
I must have noticed this before, but it bothered me this time. I opened the lower, drain, on the lower transmission with the top plug in place. some oil started leaking out. I quickly screwed in my pump hose and the leak stopped. I then removed the top plug and pumped oil in until it started to flow out the top hole. I replaced the top plug and put in the lower plug as fast as I could when the pump line was removed. I still lost at least a ounce or so of oil. Is this a problem? I think the case colds about 10 or 12 ounces of oil.
That is correct, I did not change the oil, I was just trying to check to be sure the case is full. The engine has only a few hours on the oil as I didn't use the engine much last year.
