oil mix ratio
F 117
hi i want to run pre-mix in my '89 johnson 70<br />will cheat the oil pressure switch. and cap carb nipples, and unplug oil pump.<br />thanks for your help.<br />ps any bad habbits whith this motor? its on a 20' pontoon
Hooty
Re: oil mix ratio
50:1. One pint of oil to 6 gals. gas. <br />That engine is a good, solid, dependable engine. Keep up the regular maintenance and it'll give thousands of hours of service.<br /><br />c/6<br />Hooty
