I'm with Joe Reeves as I remember a bulletin about changing the oil mix on older motors. I thought it came out around 1966 or so when OMC came out with their own outboard oil. Back then it was "certified" by the BIA, the forerunner of NMMA.<br /><br />If I remember correctly, it was for 18hp and up ( or 10hp and up) motors could run 50:1. The old 3hp was all bushings, as was the 5.5 and the infamous 'rod-throwing' 7.5 hp models and those were kept at 24:1.<br /><br />Many of the early and mid-'50s motors used 16:1 - 1/2 pint per gallon.
