Re: oil mixture rdl-23 jonhson seahorse 40hp pls
No offense intended towards anyone here of course, but OMC came out with a bulletin when the 50/1 oil came into existence which (cutting to the bottom line), read somewhat like the following.<br /><br />Any of OMC's engines which have powerheads consisting totally of needle, roller, and ball bearings pertaining to their main bearings, connecting rod bearings, wrist pin bearings, may use the 50/1 fuel/oil mixture safely.<br /><br />The 1961 40hp Evinrude/Johnson falls into the above catagory and may use the 50/1 mixture.<br /><br />However any engine that incorporates a bushing type bearing, whether it is a main bearing, connecting rod, or wrist pin bushing should use its original recommended mixture, stated at the time of manufacture.
