Re: OIL PAN REMOVAL
if you do have enough space under the engine to work with you should be able to get it out without removing the engine, usually the oil pump is in the way and you have to drop the pan far enough to get it out... otherwise there is no other way without pulling the engine out or at least lifting it high enough <br /><br />Hope this helps<br /><br />Dom
