Oil Pan Replacement
goetzco
Need some advice on replacing oil pan. I have a 2005 Bayliner with a Mercruiser 4.3 Serial #OW346485. Replacing the long block in it and the oil pan has cracks in the bottom. It wasn't leaking but the cracks are visible. I'm going to replace it with a new one. I'm having a little trouble finding the correct one online. Can anybody help me out, and I assume an automotive pan is different from a marine pan?
Thanks...
goetzco
Re: Oil Pan Replacement
Okay, just found the replacement part number so I'm good on that.
Still wondering about any difference between auto and marine pan...
Nope,..... If ya use a Steel pan, paint it Well,... I like Rustoleum,...
goetzco
Thanks Bond-o...any idea what would match up as far as an auto pan?
Ayuh,... I'd pull yer's 'n see if it's got a baffle or not, 'n go from there,...
goetzco
Anybody have an idea on which model of GM will match up?
