FYI.....<br /><br />If anyone has a Mercruiser 454 Mag 7.4 Litre (I believe '97 models and after) the Oil Pan Thread Size is 12mm. I found this out after alot of research.......In case anyone is getting the Stearns Crankcase Oil Drain kit, you will need the extra adapter. The bolt that comes with the kit is NOT the right size!
