mr.bobdobalina
- Sep 6, 2010
- 18
Just started on this problem so I don't have all info yet. But here's where I am:
had the boat out the other night with friends coming down from WOT for 10 minutes the oil pressure alarm went off. Guage which is suspect as many of my guages do not work, said oil pressure was good between 20 and 45 psi.
Oil levels were fine. When I got back the next day i disconnected the sender for the alarm and resumed using the boat.
I have been noticing a white smoke coming from exhaust, bad idle, but otherwise smoothly running, little hard to start but 2 tries ok.
Checked the oil today and noticed it was way way down. Don't see any oil in bilge, pressure still looks good. Filled it up again with oil and took her for a spin. Too much smoke for my comfort. Although it's not too much most people wouldn't notice.
It smoked a good bit after first start, and then seemed to run clean at idle at the dock. But underway and underload the smoke appeared again.
Trying to get my dockside vp tech to the boat in time for the weekend but not sure he can make it.
Any ideas. Where to begin the troubleshoot diagnostics.
