Hey,
Looking for any help.. I had my Maxum 1900SR V-8 Carb. Alpha 1 in for repair. Just got it back last week. Took it out and it ran great.. BUT
I noticed that my Oil pressure guage when I start the boat shows a little lower than the mid range of the guage. I take up thr RPM's and the pressure come into mid range.
When out and in gear it runs in mid range but if I take it down a little on the RPM's I see the pressure come down a little as well.
On my way back to dock yesterday I pulled back on the throttle to ease into the dock the pressure fell and the engine stalled.
It started right up again and pressure did the same as I described.
I recently had my shift shaft seal, shift cable and PVC valve replaced. Had water leaking from my shift cable. Replaced my water pump in the spring. Mech checked pressure on electric pump in April and said it was ok as well.
Any advice as to what I should be looking at here?
