CaptainSnake
- Mar 19, 2022
- 8
I have a 1999 ficht 150 and after running fine for over 100 hours (I bought it used in June of 2018) on the water for almost 4 years of fishing seasons it now is running a bit rough and at a fast idle (approx 1200 rpm, I have the diagnostic software as well) and has some milky white fluid (water and unburned fuel or oil I assume) coming from the prop exhaust hole that was never there before. I have changed plugs & water pump twice( just did the water pump). No issues with those. Also just changed the seals on the upper driveshaft bearing and shift rod seal assembly as I had a bit of water in my lower unit. On the diagnostic software when the motor is off everything shows as fine and there are no active codes. Once the motor is started and running the software shows an "oil pressure fault" on the monitor page but no code on the page that shows error codes. Anyone have any idea what that "oil pressure fault" is or what will, could or would cause the milky stuff to come out of my prop exhaust? I know some say it could be excess oil from winterizing fogging but I don't winterize as I live in Texas and can usually fish all year. First software pics are from today. Last 2 are from last year when I first noticed the problem. Have not run it between the 2 test times at all except for the testing times.
