The other day I went out on the boat and noticed no oil pressure, so I immediately killed it. I waited a little while and check the oil, full. So I figured the gauge had gone bad and went about my way. The boat ran fine all day, so there was actually oil pressure, otherwise it would have blown up
I got a new gauge last night and am putting it in now. It still shows no pressure. I still have plenty of oil. I have a good ground, good constant 12v, and the signal various in voltage as the rpms change. I took a ready with a volt meter at what I thought was the sending unit, on the top back of the intake manifold. The voltage changes with rpm, same as at the gauge, which should indicate no cut in the wire. What am I missing. I really need to know if the oil pressure actually does go out. Thanks
