oil pressure issue 4.3 mercruiser
Hi to every one on iboats. I have oil pressure probleme on my 4.3l mercruiser. I was running, doing some break in test on my freshly rebuild engine. I ran for about 15mins than my engine stall. I start it and it stall after 15 sec. I start it again and same thing!!! I found that I did not have any oil pressure. I put the boat on my trailer to do some test at home: 1. Tested the oil prssure sender unit, good. 2. Removed the pressure sender, started the engine, no oil is comming. 3. Removed the distributor, took a drill and ran the pump, oil is comming. 4. Installed the distributor, started the engine, still have no oil comming.:confused::confused: Did somebody have any idea of where the:mad::mad: problem?????
thanks
Re: oil pressure issue 4.3 mercruiser
Ayuh,... Sounds like a problem between the cam, 'n the oil pump drive...
What do you mean? My cam is new, all cams bearing are new. I do not figure what could be wrong!
I removed once again the distributor to inspect it and it's seem good. I suppose that the drill was able to let the pump get some oil but not enough to pull some pressure this is why I think that my pump is bad! Somebody has any idea?
You were wright Bond-o, I removed the oil pan and what I found in it, my oil pump!!! I propably miss-bolted it when I rebuild my engine!!!
Ayuh,... Glad ya found the Problem...;)
