Oil Pressure Sender for 1990 4.3 Mercruiser
ahunter4063
I need a new oil pressure sender for my 1990 4.3L mercruiser engine. Serial number is OC765828. I am needing to know the OEM part number so I can cross reference at the local NAPA store. I’ve read these things are screwy about the OHM’s and the oil pressure gauge so I will pass along that the gauges are original to the boat and say celebrity on them which is what the boat is. Hopefully that helps identify what the gauge(and OHM’s) would be.
Thanks in in advance for your help
