Re: Oil pressure Switch Wiring For Fuel Pump
I had some trouble following the "humps" until I discovered the magnifying glass...
thanks Don S for the assurance that it was getting power during cranking.
Your diagram does not have the pin number configuration for the harness connectors, so I will use the relative positions top to bottom for reference.
The lead you have coming from the battery positive terminal to the fuel pump relay pin 30 should be coming from the TOP purple wire, on the engine side but BEFORE any ballast resistor component if any. That way it can only have power if the key is in On/Run.
Also, the NC Normally Closed terminal on the oil pressure switch should probably be fed from the engine side of the harness from the yellow/red wiring that feeds the starter relay exciter pin 85. In essence it is wired to the same place now, but from the helm side of the harness. Just seems better to have the wiring all on the engine side.
Having two purple wires is confusing, but the LOWER purple wire is really just an extension of the WHITE lead from the coil negative post that goes to the breaker points (or other triggering device). The GREY wire is the tach wire and is only on the helm side of the harness. The connector is used to make the "splice" for this junction.
I apologize for just text. I wish I could diagram this, but I lost my Visio and Cad when my job (and me) got outsourced.
