Oil Pressure
bsh21wash
What are some causes of high oil pressure? My gauge is reading anywhere from 60-80psi at full throttle.
Re: Oil Pressure
Ayuh,....
Cold Oil, or a Faulty Gauge come to mind.......
Possibly a Plugged oil filter....
bomar76
Re: Oil Pressure
Running 90 weight gear lube as engine oil will do it too....ask my ex brother in law ;)
Don S
Re: Oil Pressure
that must take a long time to fill :)
And a whole lot longer to drain
Get a mechanical gauge and verify that it's an actual oil pressure problem and not a gauge/sender/wiring problem.
johnbo
Re: Oil Pressure
Seems not that unusual to me. My '96 4.3L will will show right at 70 psi at 2-3K RPM when it is cold. After cruising for 5-8 minutes the oil pressure will drop to the high 50s at the same RPM as the engine fully warms up. I get about 30-40 psi at idle (with some fluctuations).
30w Delo 400 and Volvo oil filter, both changed yearly.
Just my two bits,
johnbo
bsh21wash
Re: Oil Pressure
Im thinkin that it might be a faulty gauge. My volt gauge will read nothing until I tap it and then it goes right to 12 volts...Same with my trim gauge???
Don S
Re: Oil Pressure
Your volt gauge doesn't tell oil pressure. Like I said, get a mechanical gauge and test it before just throwing parts at it and hoping you happen onto the problem.
